When we talk about commissioning, maintenance, and validations in critical environments, there is one point that always weighs heavily on the final result: standardization. Even with good equipment and experienced professionals, performing tests manually, switching between files, opening different software, and consolidating evidence manually increases the chances of variation, rework, and loss of traceability.
This is exactly where Test Plan Software comes in, a solution from the CTC (Conprove Test Center) ecosystem created to organize and automate tests in sequence, integrating different files and software into a single routine — and finishing with the issuance of a single report.
Product page:
What is Test Plan Software?
Test Plan Software is a feature that allows you to execute sequential tests based on different files and CTC software. Instead of operating separate steps and then consolidating everything later, you build a “plan” with the activities in the desired order and run the routine in an organized way.
In practice, it works as a test orchestrator: you define the flow, execute the steps, and obtain consolidated evidence of what was done.
Main features (in practice)
1) Creation of sequential routines with any CTC software
Test Plan Software allows you to create routines including any CTC software. This is especially useful when your procedure involves multiple validations, checks, or complementary steps.
2) Insertion of previously tested files (smart reuse)
A feature that delivers immediate productivity gains is the insertion of previously tested files. This makes it easier to:
- reuse validated routines (internal best practices)
- reduce preparation time
- maintain consistency across teams and projects
3) Pause routines (with alerts, figures, and sounds)
You can insert pause steps to organize flows that depend on human intervention, connection changes, circuit switching, authorization, visual inspection, and so on.
And it does not simply “pause”: the pause can include figures, sounds, and warnings, making the procedure clearer and reducing the risk of non-standard execution.
4) Insertion of text routines (guidance and traceability)
The ability to insert text routines helps transform the test plan into a guided procedure, supporting:
- standardization of the step-by-step process
- documentation of what must be checked in each step
- clarity for training and execution by different professionals
5) Execution of any executable (Excel, parameterization, and others)
In addition to integrating CTC software, Test Plan allows you to include any external executable, such as:
- Excel (calculation spreadsheets, checklists, internal templates)
- parameterization software and manufacturer tools
- auxiliary applications used in the team’s routine
This turns the plan into an end-to-end flow aligned with the operational reality of teams working in the field or in the laboratory.
6) Issuance of a single report
At the end, the system generates a single report, consolidating evidence from the executed steps. This is crucial for:
- increasing traceability and repeatability
- reducing manual consolidation errors
- facilitating audits and technical deliverables
- speeding up the closure of commissioning and validations
Benefits for engineering, operation, and commissioning
By adopting sequential and standardized routines, teams tend to achieve direct gains in:
- productivity (less context switching and fewer manual steps)
- quality (more consistent execution and reduced variability)
- operational safety (guided procedures and alerts)
- traceability (consolidated and organized evidence)
- training and scalability (easier to replicate methodology across teams)
In an environment where outage windows, asset availability, and evidence traceability are decisive, automating the testing flow stops being a convenience and becomes a competitive advantage.
Where to see details and learn more
For complete information about Test Plan Software, visit:
