Trivia Trens Acquires the CONPROVE CE-7012 Test Set for Power System Applications
News
Trivia Trens Adquire a Mala de Testes CE-7012 da CONPROVE para Aplicações em Sistemas Elétricos de Potência
The modernization of power systems requires test equipment capable of supporting both conventional installations and IEC 61850-based digital substations. Reinforcing its commitment to quality and reliability, Trivia Trens has acquired the CONPROVE CE-7012 test set to expand its capabilities in testing, commissioning, and maintenance of power systems.
The CE-7012 is a comprehensive solution for testing primary and secondary equipment, delivering high accuracy, automation, and full support for IEC 61850 and IEC 61869 standards.
A Complete Solution for Electrical Testing
Designed for utilities, industries, system integrators, and engineering companies, the CE-7012 combines multiple testing functions in a single portable device.
Its main applications include:
  • Protection relay testing;
  • Current transformer (CT) and voltage transformer (VT) testing;
  • Power transformer testing;
  • Circuit breaker testing;
  • Winding and contact resistance measurements;
  • CT saturation curve testing;
  • Protection and automation system testing.
High Accuracy for Advanced Testing
The CE-7012 features:
  • 6 current outputs;
  • 6 voltage outputs;
  • Digital Signal Processing (DSP);
  • Signal generation up to 3 kHz.
This architecture enables complex tests with outstanding accuracy and repeatability.
Ready for Digital Substations
The CE-7012 fully supports modern digital substation architectures, including:
  • IEC 61850;
  • IEC 61869;
  • GOOSE;
  • Sampled Values (SV);
  • Process Bus.
It also allows users to compare conventional and digital signals, validate operating times, and test modern IEDs.
Applications in FAT and SAT
The CE-7012 is widely used for:
  • Factory Acceptance Testing (FAT);
  • Site Acceptance Testing (SAT);
  • Commissioning;
  • Preventive maintenance;
  • Operational diagnostics.
Its automated testing capabilities reduce execution time while increasing the reliability of results.
CONPROVE: Technology for the Power Industry
For more than 40 years, CONPROVE has developed equipment, software, and training solutions for professionals working in protection, automation, metering, and power systems.
Trivia Trens’ acquisition of the CE-7012 reinforces the industry’s confidence in CONPROVE’s engineering solutions and highlights its commitment to the modernization and reliability of power systems.
Learn more about the CE-7012:
CE – 7012
