Como se familiarizar com o uso dos softwares automáticos do Conprove Test Center (CTC)?
[PT/EN] Utilizando o modo de simulação o usuário pode se ambientar com os recursos do software e consolidar a metodologia utilizada, sem a necessidade de conexão com o hardware. Somente os aplicativos considerados automáticos possuem o modo de simulação, sendo eles: Differential, Distance, PSB OoS, Harmonic Restrain, Synchronism, Overcurrent, Volts/Hertz, Transducer e Meter.
Saiba mais acessando nosso Fórum: https://mla.bs/dea902ad
Using the simulation mode, the user can familiarize themselves with the software features and consolidate the methodology used, without the need for hardware connection. Only the applications considered automatic have the simulation mode, namely: Differential, Distance, PSB OoS, Harmonic Restrain, Synchronism, Overcurrent, Volts/Hertz, Transducer and Meter.
Learn more by accessing our Forum: https://mla.bs/dea902ad
